Group Bulbs to Lamp
Level1-Base shared this idea 10 years ago
Hi all,
quick question: I have a Zipabox with several bulbs 'Osram Lightify PAR 16 50 Tunable White'. I would like to group five of those bulbs to be able to control a lamp in my kitchen. As those bulbs are dimmable, it would be great if we could maintain that function. Ideally, I would have one device called 'KitchenLamp' that allows me to a) turn on / off and b) set the dimm level of the five bulbs.
I am beginner at Zipato so that it might be an easy one for you guys to answer it. I am quite frustrated because I got the hint to use a virtual switch and the rule creator but I wasn't able to get it work. I would highly appreciate if somebody could give me very specific advice.
Thanks a lot and all the best
Replies (15)
create a group of lights: ea. kitchen
5018bea6add9a198d0ea7a0fd9f7f09b
04f1b8993e75a148bdad99702380412d
Decide a dimmer that you hopefully have, to be the master controller for the rest of the lights. Like I have done with the lights in the living room(Qubino dimmer).
Create a rule with the dimmer that change value of a variable. You can cal the variable what ever you want.
Let this Variable control the group of lights. Something like this:
ba0031af498306ffac227b2e10626348
deleted
sorry wrong info, you need to create a virtual level control, make it a light instead of http device, and use the set puzzle not the action puzzle. You can do the same for colour intensity
But then it is hard to control with a button on the wall?
thanks for your reply. That sounds really good. I tried to rebuild it. Unfortunately, it doesnt work :-/
Below my latest rule. I tried hundreds of variations. There must be one error in it that I cant find. Any idea?
Thanks a lot!
Files: Rule.PNG
Can you trie any other lights?
Have you synced both on right and left side of the web interface?
And what type of divice is your dimmer?
hahaha - I cant believe it. Spend hours on that little thing in the last days and basically just didnt know that I have to synchonize both sides of the web interface XD
THANK YOU so much!!! It does work now.
https://youtu.be/CP-fG9gh9xM
Angry again.... I need a good BUG spray!
Use ImperiHome. There you can use composit widgets. That mean you can add several lamps under one dimmer. I have tested it with several lamps works. You even can compose ligthify and hue lamps together with z-wave dimmers.
Sadly the Dimming of ImperiHome is not a perfect solution.
https://www.youtube.com/watch?v=sYG2uc3Of7A
Tried it and liked it a lot!
But the interface is still a lite dumb that you have to precisely hit the dimmer knob, otherwise the hole screen moves.
Create a virtual level control >> then use this vault in the dimmers. Like Adrian post.
As usual smart HeroS!
A stand-alone article is a kind of essay that is likely to be used by the candidate or to explain who the author really is to people who have nothing to do with them www.paraphrasingonline.com. It is ideal to start with multiple facets to draw readers' attention to the exhibit. The essayist must clarify abilities, individual characteristics, interests, and so on.
Thanks to the author for writing the post, it was quite necessary for me and liked it. I wrote a note on the about this. I will be happy if you read it and accept it. Thank you for your concern.
Thanks to the author for writing the post, it was quite necessary for me and liked it. I wrote a note on the about this. I will be happy if you read it and accept it. Thank you for your concern. https://ometv.onl https://chatroulette.top https://omegle.wtf https://bazoocam.cam
I would like to find tips on how to produce a thesis proposal on this topic.
