Issue with "simple" rule
Peter shared this problem 9 years ago
Hello Team,
Issue #1
I have created a simple rule 'Sapin astro ON':
when schedule time => astro
every days
action put a plug on
this rule is not working at all
I do not know why,
it is the same for the others:
Sapin 2245 OFF
Sapin MOV 645 1345 - 40min
Issue #2
i have another issue with rule "Lampe Debut Astro"
same thing this rule start with Astro and turn on
i have created another rule to turn off "Turn Off at 10:45"
for some reason my light turn off at 21h45 instead of 22h45
do you have an idea?
thank you
Replies (13)
Post some screenshots the rules plz
Thank you for your prompt answer
here the "Simple" rules
I am using the same rule for my light (Lampe Debut Astro)
Don't see anything wrong. Did you do a sync?
Put a message in the rule so see if it runs and try without the scheduler (with a virtual switch).
of course. i have sync many times.
change the rule from ON to OFF => sync OFTT to ON => sync
nothing
unplug electricity from the box
restart
sync again
nothing
Do you see normal values for sunset and sunrise in your virtual weatherstation?
did you sync on the right hand menu not the left.
try using a simple time now = 22:45 instead of the scheduler. Have you configured your timezone correctly in the settings?
Hello all
sorry for the delay of my answer but with Christmas and the new year ...
so i have followed your advice and updated the rule.
when : using my Fibaro FGMS-001 with condition all
if: time now is between 5:45 to 22:45
action: turn on the light
nothing happen :-S
do you have another advice to share?
Post the rule plz (screendump)
Did you create a virtual weather station? Without it the system does not know which timezone thebastro values apply
yes i have created a virtual weather station.
i have set up my location and time zone according to where i live
did you sync with the right hand sync button not the left menu?
Can you control the device normally through either app or control centre?
Is your green LED on the zipabox flashing or constantly on with an occasional flash?
And please show another screen dump.
Hello Adrian
thank you for your answer I did a sync with the right button and it worked!
could you please explain the difference between both icon (right and left)?
my zipabox is constantly light on with occasional flash.
Hello Peter,
"Synchronize" button on the left side of your UI syncs the Box meaning Devices, Security partition, Virtual thermostats etc. and "Synchronize rules" button on the right syncs first the Box to make sure all the devices used in Rules are synced and then the Rules.
