How to change setpoint on a thermostat?
I have a SRT321 / HRT4-ZW thermostat using association to control electric panel heaters. The thermostat works fine on its own and I am trying to move from VeraEdge where it worked perfectly.
I'm not able to change the setpoint temperature anywhere in the web UI (old and new) and not on mobile (stable and beta). Either I don't get it or it is not possible out of the box.
All I did was to include all the Fibaro wall plugs and the thermostat. Associate 3 wall plugs in the thermostat and it started working. I can see the thermostat in all the UIs but not control it in any way.
Stian
Did you make a virtual device, where the SRT is used as input and the fibaros are outputs. There you can plan your own schedule per weekday and also change the setpoint for a moment, until your schedule changes or for longer if you are on holidays.
I have not made any virtual thermostats. Is there any documentation about them?
Why need a virtual thermostat? Zipato recognises the SRT321 as a thermostat.
When I configure a Virtual Thermostat. Is it still the SRT thermostat controlling the wall plugs with association? Or does Zipato take over the control?
Stian
Stian
Zipato takes over controll. I three of the SRT321 and 6 Danfoss Thermostats as Valves. Works perfect. Every SRT321 runs several rooms with different programs. In one year I reduced costs for gas in a value all the equipement costs. From today on I earn money :-)
Thanks for clarifying Andreas :)
I can see the benefits but that's a no go for me. I want direct association so even if the controller dies the thermostats continue working. I have seen recent bugs here regarding the hysteresis of virtual thermostat. The SRT321 algorithms work spot on and keeps my temp between +/- 0.1 degC. I would not save more money handing the controls over to Zipato. If just Zipato could schedule setpoint changes.
In my opinion Zipato is working against the whole point of z-wave and direct association.
I did file a support ticket yesterday and will wait to hear from Zipato. I will probably return the Zipabox to the store as this is not what I was expecting. Heating should be ROCK SOLID as my wife is already fed up of me fooling around with home automation ;)
Stian
Stian
Hello Stian,
You are very close to your goal (Zipabox sends the setpoint value to the HRT4, and the HRT4 manages your wall plugs)
You have already associated the HRT4-ZW with your Fibaro wall plugs.
Now you have to:
1- create a virtual thermostat (add Device/Virtual device/Virtual thermostat)
2- configure the virtual thermostat(using "Devices" the tab)
- heating output : choose the HRT4-ZW
- heating input : choose also the HRT4-ZW
- thermometer input : choose also the HRT4-ZW
- thermometer fonction : choose "last"
3- use the scheduler to set the heating planning
4- save
5- synchronize
To summarize :
The zipabox knows the setpoint (according to the scheduler),
The zipabox sends the setpoint to the HRT4 (depending on the wake-up interval you setup for the HRT4)
The HRT4 controls the wall plugs
This is how I use the HRT4 thermostat at home since one year
Hello Stian,
Now you have to:
4- save
5- synchronize
To summarize :
Christophe
i've folowed your method Thanks
So I think I'm very close to my goal: adjust setpoint of my thermostat
To do so, is it necessarly via a scheduling method ?
as a french, excuse my english
Christophe
Does anyone still have this problem? For me nothing worked to change the thermostat heatpoint.
Thermostat Configurations: Real Virtual , Input to real , Output to virtual .... seems correct
But what about the Settings :
button Mode have 3 choices: Heating / Auto / Off
button Configuration have 4 choices Programm/Derogation/Permanent/Maintenir pendant ...
I can't find any users manual about those choices combinations
Olivier
Olivier
2 years later...
Still the same problem to adjust temp from the apps/zipabox
Still waiting .. Is Zipato still alive ?🤐
2 years later...
