*Rule examples that work, and ideas how to further develop them!*
If you are like me, always struggling to get the rules to work, then I would encourage you to post your WORKING rules here so that we don't have to struggle as much each time. If we could collect a few rules here it would be easy to find something that fits your usage. I'll post some of mine working rules, and I appreciate any feedback of they could be done better.
This will also give other users ideas on how to make their homes smarter :)
Actuator: Fibaro Plugin
Rule: Have the coffee machine turn off automatically after 1,5 hours and be able to locally reset the timer.
Sensor: 433MHz NEXA Sensor
Rule: Notify me when the outside door is opened between the set times.
Actuator: ID Lock Sensor: 433MHz NEXA
Rule: To circumvent a bug in the lock that sends an unlock status regardless of actual state.
Sensor: POPP Fire Sensor
Rule: Just to notify if triggered. Working on including all fire sensors into a alarm partition.
Sensor: Zipato Door/Window Sensor
Rule: Give the wife a kind reminder that she forgot to close the garage door :)
There is more here: https://community.zipato.com/topic/useful-rules-post-your-rules-here
Shouldnt we all post to the wiki instead?
Double post and unable to delete...
Sensor: Aeon Multisensor 6
Actuator: Nexa CMR-100 Dimmer
Rule: If movement in my hall, turn on LED spots for 30 minutes. After 30 minutes, turn off the lights. Rule is restricted between 05:00 and 21:00 Hrs.
Hello guys,
Rules examples can also be found in our Knowledgebase in the Rules Creator section
https://community.zipato.com/knowledge-base/articles
Hello guys,
Sensor: Fibaro Motion Sensor
Actuator: Zipato RGBW Bulb
Purpose of the rule: Set RGBW bulb luminosity to 100% if the motion sensor has detected motion and the luminosity in the room is less than 50 lux, also this rule will only turn on the light if the bulb is completely off. This is so if you entered the room and then you activated an scene, lets say, you dim the light to 50% this rule wont override the luminosity set by the scene.
Sensor: Fibaro Eye
Actuator: Scene containing light acturators
Rule: If movement is detected in livingroom and lux is below 700 turn on lights defined in scene. Rule is restricted between 05:30 and 06:30 and 12:30 and 16:00 hrs (kids coming home and does not turn on lights for their homework :)) .
Sensor: Fibaro Eye
Hi Guys, just a thought. If you remember on Henry (the master of restart detector,...if you are using Zipabox, add a stop puzzle at the end of each rule. If it made a difference for him, than more or less it should also help you.
Shame Henry will now leave this community, but still we should hold together.
I find pleasantly surprising that it is now nearly 2 weeks, and so far noone had any topic on any bugs with ZipaTile. This is a good indication...
