Zipatile Zigbee + Zipbox = ZWave, Zigbee, Bluetooth + two Networks?
Claas Voigt shared this question 10 years ago
if the Zipatile works as a Subcontroller to the Zibabox, is it possible to use the networks on both?
E.q.:
Zipabox: ZWave, Enocean, 433
Zipatile: BLE, Zigbee
Best
Claas
3
For the future we see the Zipatile as the main controller and Zipabox as the extension unit. However, it can work in the opposite way as well.
We are now implementing option for easier adding each one of devices from one Zipato controller to another. Once this is done, you will be able to do it with any of our controllers, in any direction.
But from the start the Zipatile works as a controller together with Zipabox?
Sure, you can use them both as controllers if you like. Or you can use Zipabox as controller and Zipatile as control panel only. Also, you can use our API and/or virtual devices to connect some devices between themselves even without the wizard which we are working on.
Sebastian, Claas was asking whether the cluster option will be ready when Zipatile will be shipped or will it take more time to wait after we receive the zipatile?
How can i get access to the devices in the zipatile from the zipabox. or the otherway around?
From my understanding, if you have devices added to both the Zipabox and other added to the zipatile, you will need to purchase a cluster for BOTH controllers. But I think to use the sensors on the Zipatile with the Zipabox you can do this through ip. Although I am not 100% sure on this.
That is the second option Sebastian was talking about which would be free. That way the zipatile would still remain as a device with endpoints, and will not do any controller functions.
I'm expecting my Zipatile to arrive this week so I will give update on this, but either way the Zipatile has a lot faster hardware than zipabox so I would not leave Zipabox as the only controller. I would switch everything to Zipatile.
