Fibaro RGBW Controller, wrong channels values shown
Guest shared this problem 10 years ago
When i set the Value for one single channel of the RGBW Controller with a rule, then the value for this channel is false within the device manager. For example the value of red channel is set to 50%, but it shows 0% for this channel. If i look into the RGBW Controller the shown value is shown correct.
I have similar problems. my question: Is the Fibaro RGBW Controller integrated in the zipabox? When yes, it is a ver bad implementation!
I could never manage them to work. I would need them as only output but no chance at all. Tried so many different things.
Where can I find an official list with all supported devices?
I had similar problems with a Qubino DIN Dimmer. The official answer from Zipato support:
I have just made the device descriptor for the Qubino DIN dimmer and it should now work properly with the available configuration.
Is it possible to check or change the device descriptors?
Ivan, while you are working on this item, can you also work out the opportunity to allow the different programs to be run on demand (parameter 72) so we ca use one button to activate different light modes (programs 6-10)?
