Zipatile Home screen
Is there a way to change the first Homescreen as I do not like the analog watch and I do not use thermostats.
is the first screen just a typical android wake screen? Can you use a different launcher?
Yes it is possible. You can customize your Zipatile by pressing and holding finger on empty part of screen. From there you can select your wallpaper, add widgets and choose your default home screen.
Is it possible to add an app to the bottom of the home screen? I tried but the app just disappear... Is there a setting I need to enable or something?
Hi guys, start playing with the zipatile a couple of days ago. I used aio downloader and sideload to load the app apex launcher. This way I can customise the home screen, to have whatever I want.
Next i'll look into getting google play services installed so I can load other apps. Would be very handy to have the ability to add tasker and its associated plugins to this tablet also. I also like tinycam for camera widgets.
The only thing I am a little dissapointed with is the ability to use the touch buttons. It is only via the rule creator. This should really be used on the tablet. Now if I have 2 Zipatiles, and I need to use a touch button for a light on the second Tile, I will need to have a cluster licence. Not fair.
I will work around this by using imperihome, scenes, and tasker to create an app from a Zipato scene, then the touch buttons can activate the app(scene). Still, an annoying and convoluted method to activate a scene. And I still need the Zipatile with play store installed first.
I have tried to install Google Play Services but it always crashed. So I use a different market store now and it works perfectly except that Apps which needs the Google Play Service of course.
The Touch Buttons can be configured without rule creator (Depending of what you want to do with it). There is an app for this installed.
