Everspring HSP02
Sandy Thompson shared this problem 13 years ago
Not a Problem
I know this question has been asked before, but I can't seem to get my solution to work.
I want to HSP02 to trigger a little when motion is detected, only when the light level is below a certain level.
No matter how I configure it, the motion detector seems to trigger regardless of light level. The other configuration parameters work correctly - Retrigger time and OFF trigger time.
Reading the Everspring user manual, Alarm signals (motion only) are sent to group 1 and Motion/Light triggers send a BASIC_SET Command to group 2.
In Zipato there is no way to see these groupings.
How do I get this device to work correctly?
ZIpato ignores light level settings on Everspring, you should use rules and check current level.
