3G Stick offline but working (sometime)
Carlo shared this problem 10 years ago
I have a 3G stick attached to a battery backup.
At the first install i followed the Zipato procedure (https://community.zipato.com/topic/zipato-backup-module-3g-stick-troubles) and the 3g stick were instaled and available undel the network IP Backup.
I tried to remove the LAN and the zipato were connected to the cloud and I was able to sync the zipabox, so I assume the stick is working.
I inserted again the LAN cable and the connection swithed from the 3G to the LAN.
Now the stick is marked with a red dot in the web console (as offline) but it's working randomly.
Sometimes it get connected, sometime I need to remove the stick and insert it back in the USB to get it working... but always marked offlline.. see attach.
Any Idea (I'm using firmware 1.0.17)?
THere's also some inconsistency in the web UI.
In the summary say 2 offline devices, in he device manager say 1 device offline but list 2 devices offline.. see attach
