Is it possible to use dimmer state as condition ?
Cyril shared this question 13 years ago
have tried without success to use dimmer (AEON LABS Smert energy illuminator) as a condition in rules.
for example : if level > 50% then ...
Is it possible, and if not is it planned to add this possibility ?
Thanks a lot
Replies (17)
It is possible, what are you using as "when" in this rule?
A motion detection
and for example in an other rule i want to try :
when level > 50 :
wait XX s
Switch off
(to emulate light timer)
I have found for a "simple" ON / OFF" Module like AN157, I put the "Control" in the "measure" and it works, but I can't put the AEON LABS micro module n the "measure"" block
You can use dimmer as rule trigger.
Example:
JLa0hMDUfcAn9J0Jt02s
When I add the Aeon Labs smart energy, that's what I have (attached file)
I don't know what are each value.
This dimmer measure power, maybe one or 2 values for that... but there is many more than 2 values.
Ok, your device was not fully supported. Now we added support for it (you will see it as "Dimmer with meter"). Try now to create your rule.
Tanks, I see now the 3 states (cannot test now in real conditions)
How can I do the same for my others dimmer with meter ? I don't found the category.
Thanks again
Now we applied descriptors to all of your dimmers.
OK thanks, I will ask you again here when my 2 new dlmmers will be installed (They are actually in their boxes)
Thanks again !
SOrry to post again but there is the same problem with my 2 AN157+.
When I put them in the "meter" box, I have no choice : "no attributes"
Impossible to control if it is ON or OFF
In my memory it was working before, but I am a new user of the zipabox, I have tried many different things, maybe it has never worked.
I have tried to exclude / include one of the 2 module without success.
Is it the same reason ?
ON/OFF is state not value that you measure so you should put it in sensor puzzle if you want to use ON/OFF events.
Thanks.
Is the "Sensor" puzzle is returning the state or the action ?
If I want to control the state of the plug instead of the "on/OFF" action, what can I do ? Is it possible ?
Thanks again
Now I'm not sure that we are talking about the same thing.
If you want to control your switch/dimmer, there is only one action puzzle. You put your device in it and choose action (dimmer doesn't have on/off actions, so if you want to turn it off you should choose action 'Gotovalue' and set value to 0).
That was a question for AN157. Thanks for the answer.
I have tested and answered :
If I put the sensor puzzle (with the AN157 inside) in "when", the next steps are played when I switch the AN157 (ON, OFF, or ANY)
If I put the sensor puzzle (with the AN157 inside) in "If", the next steps are played if the AN157 is in the required state (ON or OFF)
Thanks again !
there are installed now.
It is a "2" verson, the problem is different.
I have the "cumulative" value, but not the "current"
Thanks for your help.
My problem is always here.
My 2 new dimmers are registered on the box, but a value is missing :"current_consumption"
Thanks for helping me
Always the problem here.
I join capture of it :
- couloir : OK
9ILpAIARHETM5Jz168zB
SDB : NOK
2pL8HztJst8ObeNbVBkG
Is it possible to solve it ?Thanks
