Zipatile Camera gives error message
Laurent Birgen shared this question 9 years ago
Hy
when trying to use to the Zipatile Camera I get an error message stream could not be loaded.
Is there something to activate ? I did not find any parameters in the Tile Parameters.
My Zipatile was under repair, due to a broken relay, for some time and I tried it before and it worked,
now as I have it back I don't know if its some change in the newer firmware to apply to get it working or as side effect from the repair the Cam is now not working anymore.
thx
Laurent
Replies (11)
i have the same problem
what have you done to resolve it??
Hi guys, I also have this problem. I factory reset the zipatile and the problem went away. Now it's back. Please help.
Thanks, Andrew
I have the same problem.
- No Camera picture displayed.
- When I either select SD or HD, error message comes up stream could not be loaded.
Does anyone have a solution?
Same problem here!
I also have this problem and I have an open ticket for some time and they have not given me a solution.when I open the camera from my zipatile the ip camera application opens and the screen remains blank.
3
Same issue for me...ticket opened with answer that they will forward to the development dept. Currently no solution for me.
Hello
The same for me ...
I've opened a ticket about this problem and support specialist entered data in camera settings:
33df4c5ece90ae1d79c3f3fb8ef62b15
And i can view video stream in vlc player (open steram via URL):
rtmp://*zipatile_IP_adress*/zipatile/1
rtmp://*zipatile_IP_adress*/zipatile/2
I have entered the data in the configuration of the camera and I still can not see the camera from zipato web from the zipatile and from any smartphone.For a long time I have had this problem with the zipatile and zipato has not yet been able to solve it.
same here
I've opened a ticket and I've received this upgrade for the camera and now the hd stream is running correctly.
https://drive.google.com/file/d/1eMKtLnG7KhLrvfKmpdeX5wa81ccQftQu/view?usp=sharing
Hola David
I downloaded the application from the camera in .apk and I can see the camera. now I have the problem that the image looks backwards
What version of the IP Camera app are you using?
I got 2.1.4 and it is still not working
This app doesn't install on my mobile, and nothing happened on Zipatile...
any help?
Thank you for your quick answer.
Could you please tell me how to install this webcam-zipatile-release (2).apk file on Zipatile ?
Thanks in advance
Le jeu. 11 avr. 2019 à 16:17, Zipato Support Portal <mailer@3plus.hr> a écrit :
hi karl
Download the application on a mini usb card and insert it into the zipatile then go to applications and look in the file folder on external usb card and find the file and install it.
I installed it and the image of the camera was upside down.
