Issue with readings of Zipato Micromodule Energy Meter
Hello community,
I have just purchased and installed a Zipato Micromodule Energy Meter (https://www.zipato.com/product/micro-module-energy-meter), my houses drop is two phases of 110 VAC, neutral and ground. I'm having issues reading correctly the voltage (see below) and the power factor (see below), I have contacted zipato support and they said they tested theirs in the lab and it is working properly with current firmware.
Mine is connected to Zipabox running 1.1.38. Have anyone experienced similar issue?? The other readings appear to be correct.
