SEND A HTTP NOTIFICATION (PUSHINGBOX)
i made a rule with HTTP request, Post, URL=http://api.pushingbox.com/pushingbox?devid=vxxxxxxx but i doesn't work.
I send an Email in the same time, and i receive it.
When i put this URL in Chrome, i receive a notification on my phone.
I try with Post, Get, Put, nothing works.
Have you an idea ?
I added a rule on your box just to see if we're getting the requests, and it looks OK, I see requests.
The URL you've entered is OK for Get request on pushingbox, not Post.
Don't you need to set a variable on pushingbox to make it do something?
It works this morning, but i don't change anything
Thanks for all.
Thanks for all.
How to add the value of a meter in parameters of the request, for example the temperature of a thermometer?
I know how to add it in the request &temperature=25 for example and in the text I set something like: "the temperature of the room is $temperature$" but I do not know how to do it in the rule creator !
Currently you can't use dynamic parameters in "HTTP request" puzzle.
Do you plan to implement it?
Yes we will implement it.
You can create an Idea so others can vote on that and speed up implementation ;)
is there, somewhere, an example to use HTTP request in POST mode?
Regards,
William
Regards,
William
If you would use PushOver application this would be:
Method:Post
URL: https://api.pushover.net/1/messages.xml
Headers:
Body: token=yourtoken here&user=usernamehere&title=Zipato&message=yourmessage
Method:Post
Headers:
Look here:
http://www.domotica-blog.nl/post/push-notificatie-op-zipato
Look here:
Great! Thank you HeroS
Is it possible to send a value ?
for example :
Body:
token=yourtokenhere&user=usernamehere&title=Zipato&message=temperature+:+XX
where XX = temperature value
for example :
Body:
Not like that.
But you could make rule...
When temp=!0
If temp=10
http request temp=10
If Temp 15
http request temp=15
etc
Not like that.
When temp=!0
If temp=10
If Temp 15
etc
of course, yes!
thank you.
of course, yes!
thank you.
I made a rule with HTTP request, Put, URL=http://api.pushingbox.com/pushingbox?devid=vxxxxxxx but i doesn't work.
Test on Pushingbox virtual scenarios, i receive a notification on my phone.
But made a zipa ruIe HTTP request, tried with Post, Get, Put, nothing works.
Please help me how make a rule (when motion send me notification) which can send notification on my mobile with Newtifry ?
Hi SonyB,
the answer is in the message of slashroot:
In HTTP Request dialog box set this:
Method:Post
Headers:
Body: token=yourtokenhere&user=usernamehere&title=Zipato&message=yourmessage
Hi SonyB,
Method:Post
Headers:
Thank you William NOEL
