Cannot add nest in Zipato Control Centre
John Wingfield shared this problem 8 years ago
Hi all
I go to add device and then select nest as the network. I follow the link and get the PIN code, but every time I enter the PIN code into the Control centre its comes up with a long winded error message which I have attached to this post.
Can anyone advise what I am doing wrong?
Replies (8)
Same problem here, anyone a solution??
Definitely open a support ticket so Zipato will have a look into it.
You will probably need to add your controller serial into the ticket so they can identify.
May be the brand limit ?
i have Pro...same Problem here.....
Ticket is raised...
regards Helle
I had that once................ I just deleted the nest, added it again, generate new pin and then it worked.
Hi Darkwing,
Gen 2 or 1?
regards
My thermostat is Gen 3, but I had the issue when adding my smoke detectors. Not sure which Gen those are, it says model Topaz 2.7 Probably Gen 2
Edit: smoke detectors are Gen 2
hmmm, I think I could be a Gen 2. Prob...but now the Dev will take care....
regards Helle
