Scheduler starting at a precise time.
I am trying to create a scheduler that will start at 07:04 and repeat every hour like 08:04, 09:04 etc. but doesn't succeed with that, it always starts at 00, I have tried all I can see, as in the scheduler there is a start time, but it doesn't work.
I don't want any timer and so on, there are several way to do it, but want it simple with one scheduler that only repeat once a hour, before I had one scheduler that repeated many times an hour but want to have less repeating scheduler.
Anyone have any idea?
Thanks.
Manuel,
Can you post a picture of the configuration of your scheduler? This is how it should look like...
I have hourly and minutely schedulers and they work fine, however I like them to trigger at whole hours/minutes so never tried the hourly to configure it with minutes after the hour.
Manuel,
Here are the pictures, I did exactly as you did before and it never worked so I proved that way that didn't work either.
Sad.
Sad.
All this is very strange as it worked before, I have old schedulers that have a start at half every days, but I can't create any new one that works, any bugs in the new release ( 1.2.29 )?
I will make a test rule and let you know my findings...
Manuel,
I would open a ticket on Zipato Support, you are right, the first event in the sheduler starts at precise time, after that all subsecuent events are moved to whole hours, see attached.
Manuel,
