streaming Zipatile camera doesn't work
vincenzo esposito shared this problem 9 years ago
In Progress
Hallo, my streaming live camera of Zipatile doesn't work.
is there any way to resolve it?
are there other people with same issue?
thanks
Replies (8)
I have same issue. At least it does not load on my andoid app
Same issue. Specially when outside home (not same wifi network). But also at home.
Yes me to
Again, as I've said in a previous post.
Just checked on Android 7.0 and app version 4.1.5 and I gotta say its working both in local connection and 4G.
What app/android versions are you running?
0b1f6a87b94f952a43c60dd5ef01a17ab97877393c17d00bbfab4b3bf5f13f0e
I have the same version. I had probably a beta stuck in my phone for a long time so I uninstalled and reinstalled and now have 4.1.5. Zipatile camera does not load. Snapshot is working. No matter low or high quality stream. I have honor with Android 7.0
Snapshot is working.Video streaming is not working 3 days , the screen.
Edit this on Zipatile Camera:
High Quality :
rtmp://10.0.0.1/zipatile/1
Low Quality:
rtmp://10.0.0.1/zipatile/2
Snapshot:
http://10.0.0.1:8181/snapshot.jpg
Let me known If that worked
Best Regards
I have the same problem the transmission of the camera is not seen in IOS and android and the video streams are fine
Hola
the new firmware 1.3.44i apparently has problems with the transmission of the camera of the zipatile because I have other zipatiles with a previous firmware and the transmission of the cameras look good.
I have the same issue with Zipatile about 3 month...Snapshot work fine streaming don't work
Same here. Any news on this please?
since the update the camera does not work anymore.
The config is right.
the transmission of the camera is not seen in IOS and Android and the video streams
the problem with Zipatile is since about 3 months ... The snapshot works well in streaming does not work
thank you
hi
If the Zipatile Internal camera applications shows no picture (wrong camera driver) install the app below via the File explorer:
https://drive.google.com/file/d/1eMKtLnG7KhLrvfKmpdeX5wa81ccQftQu/view?usp=sharing
Bonjour Monsieur,
je rencontre effectivement les meme problemes. veuillez maider svp. ma zipatile detecte la camera en ligne, et la configure automatiquement, mais ca ne visualise pas. je vous presente les images en annexes.
cordialement,
Hi All, did anyone found a solution on this? I have the samer problem for a long time...
