no level update with association
John van der Voort shared this question 9 years ago
I have a wall controller (zwave.me) and a dimmermodule (qubino) included and directly associated.
This works fine. I can control the dimmer without the need of rules.
But i noticed that when i use the wallswitch, the dimming level in the UI/app is not updated. And with one click, the dimmer goes to that last level value in the UI/app.
The current power consumption meter however does update correctly when changing the level.
But in this way, i can not see, when i am not at home for example, if someone has changed the light level. (Ofcourse i can check de powerconsumption, but that is not convenient...)
Is this a bug or is it normal behavior with directly associated devices?
Hi, it could be related with device which you use, and that they do not support encryption. You need to contact support for those devices.
If you use Zipato controller: https://community.zipato.com/knowledge-base/article/manage-associations
