Ping device
I would like to have some kind of "polling/ping device".
It pings an IP every 10s or something like that. If the ping is answered the device is on, if not it's off.
I see alot of use for this this. the most obvius is to trigger alarm if a machine gose down but you could use it to turn off the light if you shut down a computer.
I would use it to see if anybody is home.
When I arrive home my phone automaticly connects to my wifi (and will start answer to ping) and when I leave home the ping won't be answered anymore.
If I hade one "ping device" for my phone and one for my wife's phone I can trigger rules based on arriving and leaving home.
This would be a nice feature, triggering scenes/devices when connecting to my wireless LAN...
See also: http://forum.fibaro.com/viewtopic.php?t=1519&postdays=0&
Hi Rein,
That would be nice. I have a workaround that i'm currently trying.
On my phone i'm use the automateitapp to check if i'm connect to my wifi >> if connect i send a http request (very 15 min) with valua = 1 to zipato.
On the zipato i reset the valua to 0 ever 14 min. If the valua stays at 0 then i'm away.
My wifi doens't have a data connection when she is not home. I do have one so i'm using Google latitude script.
On my comp. i'm also using a http request (with virutal sensor). When i turn on the comp i have a vbs scipt that runs and sends a 1 and when log off i send 0 to zipato.
Hi Rein,
Device polling is very important. There is plenty of devices on the market which needs to be polled in order to retrieve their status. For instance, you can have a switch which does not report it's status if toggled manually and the only way to keep Zipabox and the switch in sync is device polling.
Proposal: with Zipato smartphone application, when the application no longer detects Wi-Fi connection (one or more smartphone) after x minutes (configurable):
1) delay xx minutes (configurable), to make sure that the Wi-Fi is no longer available
2) If true, when a 3G connection is available. Sending of data to initiate, via a rule, or a scenario action.
Sorry for my english
Any news about the "Ping Device" feature ?
The workarounds using virtual device have a major flow : no internet => no detection...
Sounds like a nice feature, is it implemented?
News?
News?
News?
News?
http://zipabox.de/connection-tracking-nmap-mit-der-zipabox-beta/ (in german). But I will a solution without a rasperry or a fritzbox....
(Warning : Apple device automatically disconnect from WIFI when screen is off, this may not always be a reliable way to check presence)
I really want this function, but solved it with another solution.... Now I get problems with my Androids using the doze-function :(
Damn.... I thought I ruled the world ;)
Hey, it is not a big problem...
Zipabox is still in beta (v0.9), they'll do it for v1.0 (if it comes out one day)
HAHaha...
HAHaha...
hello,
Now, we are in 1.2.17e and no sign of a ping device in my ziatile .... not implemented yet ?
hello,
