Using motion sensor
tranquiliste shared this question 13 years ago
Hello, I have a motion sensor everspring SP814 which I added as generic zwave but I don't know how to use it in my rule.
In the when puzzle, if I add a "sensor" sensor and then I put the sensor everspring the select doesn't offer me any choice and I can't save the rule, is it normal?
Ok I think I found the way to do it by putting a "control" in the when puzzle and the testing the toggle value
I created an application note and video showing how to use the Everspring motion detector to control a light using a rule. This uses a SP103 which is very similar to the 814. This should help you.
http://www.vesternet.com/resources/application-notes/apnt-12
Does the lux level trigger also work with the SP814?
Hello DK, apparently lux level is not triggered
Noticed the same here.
Pity,
since I want my HA to be based on presence, temperature and luxlevel :-(
