IKEA remote
Hi forum!
I have managed to get my IKEA remote to pair with my Zipabox (YEAH!), but cannot get it integrated in a rule. Also, it does not show any data on the graph. Could someone point out what the issue is in the attached picture?
The IKEA light bulb functions flawlessly in another rule (YEAH!) were it turns on and off so I guess that part is ok.
I have the same issues with the motion sensor from IKEA, it pairs flawlessly (YEAH!), but show no response in rules.
I would be thankfull for any advice :-)
Best regards from
Søren
(PS: I have the zigbee extension)
I would like to check your isuse with the remote and the sensor if you send me your zipabox SN at zcerovski@3plus.hr. Also, I might need your assistance so it would be good if you are available for skype chat tomorrow.
Very interested in the outcome. It would be a boost to Zipato if Ikea, like hue, works for accessories as well. If dimming remote and motion sensor work you can remove flip-switches and have a cheap and good looking solution. Keep us posted and keep up the good work!!
UPDATE:
Željko from Zipato could unfortunately not get contact to the Zigbee module from the IKEA remote and motion sensors. Too bad. It could have been a great advantage to use the IKEA motion sensors and buttons. But thanks to Zipato for making the attempt. :-)
UPDATE:
Any updates in this topic. I managed to connect after several attempts. Can create rules with it, but it doesn't work.
Hello.
How can you connect your ikea tradfri remote controller? I try to "Add new device wizard" >> ZigBee, but not found device.
Thanks.
Hello.
Thanks.
I paired my IKEA Tradfri remote controller to my Zipabox with "Add new device wizard" >> ZigBee >> "Tradfri remote control"
But the result is the same for me. It is visible but there is no info coming from it and I can't use it in rules creator.
