How to use Weather Http module ? Any exemple ?
MilSabords shared this question 13 years ago
For testing or comparing the values it's necessesary to know the "static terms"
For exemple : Cloudcover ?? is it yes, no or true, false or little, none, fiew ..
Thanks.
/GUMOdCee3bgAAAABJRU5ErkJggg==
Replies (9)
All the values are numbers. You can see on Dashboard in which unit is every value.
For example Cloudcover is in %
So, do you have the possibility to have it on screen ?
/M3TVJAAAAAElFTkSuQmCC
So nobody have created a virtual weather Station ?
/h81ZvMHm6AgzwAAAABJRU5ErkJggg==
I have used it but since your event log gets "spamed" with all updates ill wait.
Id like to control how many events that should be reported into the log.
No the virtual weather station is not possible to use :-(
After some server update is is not working at all...
Zipato broke it in some update, But there is no response at all to fix it, and I have given up to talk to Zipato and report problems/bugs and other issues, they just don't care to fix it!
Try to add a virtual weather station it is not showen at all on iPad!
I removed my and then tried to addition again, But it is not possible, and looks like Zipato doesn't care at all about it...
I'm sorry Sebastian But the software Quality in ZipaBox is not acceptable, not for a product thay we have to pay for...
and you already talking about payed premium, start to fix a working software first!
Thanks for your answer.
This weater meters indicators is very a good idea ....
I Hop we have it soon back !!
Concerns Firmware: 0.9.998.
Hi all, I have added the virtual weather meter yesterday. All fields remained empty after installation but today the meter weather town, country was filled with a value. See attached example.
... One week later ...
Unfortunately until now i have not been able to create logica around the values of the Zipato vitual weather sensor. Because of that am using IFTTT and a Zipato HTTP device instead. That works fine for me.
I am using the weather service for a few months now and it is working fine. But there are some things to keep in mind. Under water the service uses the API from Wunderground.com. Especially for small towns this service does not give very good results. So the best thing is to visit: http://www.wunderground.com. Fill in your city and look for the results. If bad, try to use a city nearby. If the results are good and your virtual weatherstation has still problems: submit a ticket at :http://support.zipato.com.
