FGD 211, parameter modification
Yann Roland shared this problem 13 years ago
Not a Problem
Not sure the parameter modification with the zipabox works.
if i associate the module to my ZRC-100 remote and make the parameter modification, everything is fine.
If i associate the module to the zypabox and make the parameter modification, the switch seems to be always in monostable mode
When you make the changes to the parameter do you 'save' and then 'synchronise'?
Sometimes the changes do not take effect unless you sync.
Then wait for a minute for the device to update.
I have saved the parameter but not sure for the synchronisation. Where is the button to synchronise ?
Ok that was only that. Everything is fine now !
