Add a virtual switch as HTTP device
I would like the possibility to add a virtual switch as HTTP device.
It must have the posibility to give a HTTP command to switch onn and an other command to switch off.
Example:
HTTP:\\192.189.168.42\sw6\on to swich on and HTTP:\\192.189.168.42\sw6\off to switch off.
In this way I can switch it by phone and add the virtual switch to a scene for example.
Now you can add a "Virtual switch" and "Virtual level control" device. Go to "Add device" and choose "Virtual switch". You will get new device under Lights & Power (you will have actions On/Off) and in Rules creator (where you can program your rules like with any other real switch).
thank you for this quick implementation
Does it work ? I have issue with the virtual switch. In the rules creator nothing happen when I use it in a when condition.
Tks,
Tks,
yes
yes
done. I first tried to create the rule : Pilote Parents True and Pilote Parents False and as it didn't work I created the 2 other. same.
Tks,
Tks,
Seams complicated. Why do I have to create a rule for an simple ON/OFF http switch like an Ipx800?
I'm not using it anymore so ... not really
