Nexa devices not working after 0.9.999.1 update
In Progress
After the latest update today my Nexa devices are not controllable. They work fine with a Nexa remote.
Nexa devices working for me after update. Reboot your box.
Done that already a few times.
Hi Jacob,
If the problem still remains please contact us on support@zipato.com with your user credentials and we will resolve your problem.
Kind regards,
Hrvoje
Hi Jacob,
Kind regards,
Hrvoje
Hi Jacob,
have they solved it for you? Because i have the same problem with the switches. Looks like the receiving part is ok: sensors and remote controls are doing fine.
regards,
John
Hi Jacob,
regards,
John
I just sent the e-mail to support. I'll update the thread when I know more.
433MHz Oregon THGR810 Temperature and moisture sensors are not working for me after last firmware upgrade.
After firmware update the control
of all RF433 (Nexa) devices
stopped working!!!
stopped working!!!
Didn't help.
Didn't help.
None work with Zipabox. However I can control the nexa receivers with the nexa transmitters directly.
These devices have 6 memory slots and I did reset them before rejoining them.
Hi Domagoj,
I have exactly the same problems as Jacob.
It is not only a Nexa problem. But all my devices (Nexa, Chacon, Intertech) supporting the COCO-protocol have this problem. At least the RX-devices. The TX-devices (RC, motion, and dusk/dawn) are working properly. This afternoon I tried to add a new CoCo switch module. I cleared memory first and then tried to join it. The switch did not gave any response. After that experiment my conclusion is;
1. In the case of a CoCo-protocol the zipabox do not transmit at all or transmit with low power(can not measured that at this moment)
2. Or the zipabox is transmitting a wrong protocol.
Hi Domagoj,
I have a similar problem with my NEXA devices after installation of the 0.9.999.1.
Using the Dashboard I can see that signals from my NEXA remote Control are received by the Zipabox. The expected change of state occurs on the dashboard, but the switch doesn´t change state - so I guess that something is wrong with the transmission.
Trying to change the state of a switch manually from the dashbord gives the same result - change of state is indicated but the switch is unaffected.
Maneuvering of Z-Wave
switch from a NEXA transmitter works OK. After the update the communication
with the Z-Wave devices seems to be less robust - I get temporary fail
indications that I never have seen before.
Oregon THGR810 working after re-joining.
Hi Domagoj,
Either you did something. But I unplugged the box from power and ethernet.
Waited a few secs and plugged the connectors again in the sockets.
And you know what: Everything is working again.
Hi Domagoj,
Unfortunately range is not the issue for me. My devices are 3 meters away with no walls. I have unplugged and moved to different outlets. I have rebooted the Zipabox both from the dashboard and cut power. Nothing helps.
My Z-wave devices works fine.
Earlier this evening the support team managed to fix my Nexa problems. I will keep monitoring the devices the next few days.
Hi Jacob,
What was the solution provided?
Hi Jacob,
You would have to ask the support team that.
hi
i had the same problem with coco devices ... not working after update
but i got it working again .
the only thing i did is to interchange the antenne between the 433 module and the zipabox..
hi
With Zipabox latest firmware, I just today tried to add my Nexa devices. First I add Nexa PET-910 remote, and tested binding buttons to virtual switches. Work fine. Then I add one remote plug PER-1500. Still working. After that I tried to add on more PER-1500 without succes. Then any of Nexa devices didn't work anymore. Not even these, what worked before.
Nice. Now I removed all Nexa devices, reboot the box, and then tried to add them again. It wont start discovery at all, only what I get is "
Discovery process started.
Starting..."
Starting..."
How did this issue end? I have similar problems. I can control Nexa recivers from the Zipabox but I'm not ablt to join any Nexa transmitter.
My Zipabox internal 433 radio was completely dead. Now, with external 433 module all seems working ok. Or somehow ok, control range is shorter than with tiny Nexa remote, even though i have now better antenna.
Strange thing, my Zipabox can still control receivers, so it can definitely send commands. It can also receive data from temperature sensors(Oregon), so it can then receive data. However, it cannot join transmitters like wall switches or remotes. Zipato will look into this momorrow morning to see if they can do anything. Hopefully some kind of FW-upgrade will do.
Hi Torbjörn, are you using other language in your dashboard, than english? If yes, then switch it to english, and try joining again. I did not get joined even z-wave devices when dashboard was finnish.
