Scheduler rule doesn't work.
Alexandre Blanchard shared this problem 12 years ago
Good morning,
I tried to create a rule with scheduler and run scene but it doesn't work even I do synchronization. I precise that the scene works inside the dashboard.
You can see attached two pictures of the created rule.
Thanks in advance for your answer.
Did you make a new scene? / does the scene work without the rule?
Tot see if the rule is running put a e-mail message in it. To see if it works/runs.
Hi Alexandre,
if you still have this problem contact us on support@zipato.com with your user credentials and we will resolve your problem,
Hrvoje
Good morning,
I haven't the issue anymore. I don't know why. Thanks for your answer.
