Toggle is not working between zwave and Chacon (422mhz) module.
Michael Barbezat shared this problem 13 years ago
Il I create a rule : if chacon button (WBT-912) is toggle then toggle this Fibaro power switch (2x1.5Kw).
Nothing happens when I press on the button.
If I ask the light to toggle when the switch is on, it is workink but I need to press 4 times to toggle.
I need to use 3 switchs to pilot one light, what is the best solution?
Thanks for your help.
Try replacing the battery in the module.
Also try moving it out of the wall.
If you need to press 4 times, the signal is to weak for some reason.
Also check your switch and wires, a loose connection may also cause this.
Thanks for your answer!
I'll try this this week-end.
