Unable to join separate buttons on Nexa WT-2 and LWST-605
Jacob Berggren shared this problem 11 years ago
After the 0.9.999.1 update joining the two separate buttons on a Nexa WT-2 or LWST-605 as two devices is impossible. Joining one of the buttons works fine. If I remove that device then I can join the other button. It worked fine prior to the update.
I've got the same problem with the 0.9.999.2 version.
It would be great if Zipato could add support for the Nexa LWST-605. It is the exact same as LWST-615, just with two buttons instead of one.
3
Why don't you try the chacon LWST-605 device. Same device, same protocol.
Using Chacon LWST-605 worked like a charm. Thank you for the tip! I'll sure check the Chacon devices in the future if I can't find a suitable Nexa device.
Cheers!
