V3 and virtual devices with Alexa
In Progress
Is there any progres with Alexa implementation in V3 so to be possible to voice control virtal devices as in V2?
Thanks!
Thanks!
Push - any news about the release date?
Any update about Alexa integration on V3 ??
Gerardo
Zipato wrote me this month, we will see.
Good morning. news for alexa skills?
I’d like to know too, now that I have ordered my Zipatile 2 - currently all my devices on Zipatile 1 are on Alexa.
Guess this means nothing will work anymore on Alexa should I “move” to Zipatile 2?
When i first tested V3 on my Zipatile 1 half an year ago only the virtual devices didn't worked with Alexa.
All "real" (z-wave and zigbee) devices I have were discovered by Alexa and worked OK.
Nevertheless I back to the original version becouse i use a lot of virtual devices in my rules.
@Jeroen If you use virtual devices as well, I will personaly sugest to wait for full Alexa implementation in V3 and confirmation from Zipato that the virtual divaices works with Alexa before to switch to the new version.
Hi I’ve just managed to add Alexa to my master tile and link it to Alexa hub via zipato. It found 85 devices which are all work with voice. Don’t know if it should but it did.
Hi, open browser on your master tile, google Alexa app apk and download from pureapk. Install and follow instructions. Login to tile Alexa keep your mobile with you as Amazon will send a link.
Go to Alexa app and disable zipato and then re enable, it will look for devices and say hasn’t found any, but go to devices and they should be there. This only work on zipatile 2 and is very hit and miss. Hope it works.
Nathan
Sorry good luck, I will let you know if I figure it out.
Good morning. Any news for the integration of alexa into V3?
