Zipabox offline with a blue LED
Bas Troost shared this problem 12 years ago
My zipabox is offline and has a blue LEd.
Wat does that mean and wat can I do.
Replies (14)
Did it happen during upgrade?
For how long did it stay like this?
You could try to reset the device. If i remember well you need to press button 1 and 2 together and than inserting the power connector for a couple of seconds.
Maybe someone knows the exact procedure.
Try rebooting the device first by pressing the reset button on top before you do the manufactoring reset sequence as described above.
Try a different networkcable.
I do not know if it happened during an upgrade. I turned it of to replace my Router.
Now it stay's blue. Nothing else.
Im sorry to tell but by 95% sure i belive your box have been crashed by ethernet failure. I know a few boxes got this issue upon changing ethernet connection providing peak voltage to the box cousing the box to "burn".
Please contact the support/reseller to replace the box.
This happened to be too upon changing my Airport. :(
Yup, i had the same problem.
When you plug it in the router does the router show a connection?/light up?
I hâve the same problem ? Hâve you find a solution?
Yes it has to be repared bij Zipato.
Ask your retailer for a RMA.
regards Bas
Thank you for your answer.
I have the same problem.
When I turn on my Zipabox, I have a beautiful blue led. Are you sure that my box have been crashed by ethernet failure ? Because my box is out warranty.
ps : my firmware is 0.9.999.
it's not happen during upgrade.
I try a different networkcable.
And when I plug it in the router (AirPort Extrem), I don't have light up connection in the router.
Claude
I also try this :
1. Unplug power and Ethernet cable from your Zipabox
2. Wait 2 min.
3. First plug in Ethernet cable and then power supply.
4. Press and hold Button2 on your Zipabox and then briefly press (and release) Reset button.
5. Keep holding Button2 for 5 seconds (and then release it).
but it doesn't work.
Claude, it's best you contact us through the support system (support.zipato.com).
thanks for the support Zipato & univers-domotique.com.
my Zipabox is new and functional
