Zipato-web offline-in mantenance mode
Bad Wolf shared this problem 11 years ago
Dear Zipato team,
Yesterday there were a lot of (announced) maintenances.
Today, as I wake up, web site is still down without alert on Tweeter :/
The Thermostats module is getting crazy, and I can't shut it down properly as I can't access the website...
When will it be back online ?
Do you have issues with the server ?
Jean
Two problems caused this disastrous situation today. First, Hibernate-ehcache used the total amount of memory and corrupted the disk cache (the same thing happened on all the servers in the cluster). This caused that restarted servers were not working properly again and again, until we cleaned the cache manually.
Unfortunately, the second problem was that our alerting system, didn't alert the support engineer on duty, so we did the above mentioned action with the 4 hours delay.
Certainly, this shouldn't happening never, and we agree with all of the criticism in this post. Unfortunately, it happened and we are very sorry about it. Today, we will change the alerting service which we are currently using, and we will stay on duty to help you all fix you current issues.
Oldest
  • Oldest
  • Newest
Replies (19)
mee too have many problem with my three thermostats... :-( since more than 1 day...
Back online... and new FW :
Firmware Version 0.9.990Fixes:- Thermostat - handling of multiple setpoint inputs- Thermostat - hysteresis not working in program mode- 3G backup - DNS resolving without ethernet connection- IP camera - problems with Basic auth on camera when taking snapshot from rules
back online but no fully working:
- climate widget still in night modus
- status changes made by a scene don't change status under lights & power widget
it looks like the dashboard has the status of 7:00 am and there are no status changes
my climate widget won't update after modify it... >:-(
Nothing update since 7 this morning too.
I hope solve quickly the problems with thermostats in my house this morning was 16 degrees ... :-(
for all these reasons I now have done a local thermostats program using local API and this morning everything was working fine.
can you explain it?? :-)
Everything should work by now. If some of those problems still persist, let us know.
Climate widget problem:
When running program the value is Custom should be Economy 19,4
(hard reset zipabox, heating off and running program again doesn't help)
ot9LAcLiXYe48udPNtXz
I have a linux server (my NAS actually) and with some mysql tables, a a few hundreds of php codes and a very simple gui I manage my thermostats myself.
thermostats_perso
I just just local API on the zips to collect temp every 2 min and change the switch and then of course I can manage my hysteresis myself too :)
thermostats_perso
great...uhm i have a Qnap Nas wirh Linus too... how much money do you want to do this to me? :-D :-D :-D :-D :-D :-D :-D :-D :-D
http://www.meslin.fr/radiateurs.zip
There is a readme but I did it in french :(
thankyou so much... i don't know if i will be able to... but.. i try it...
Always problems with Thermostat Widget
They do not want to change mode, but not all.
It arrive since the update of this night.
If you want, i can send you ID and PW with "support"
Chris
Impressive job !
Ca fera un très bon mode "dégradé" pour mon chauffage !
Many thanks
Thank you for you quick answer and reaction Sebastian !
I did not want to by "critic" in my post, I just wanted to let you know that it is impossible to control thermostats when your servers are down.
When will you release the new Apple/Android app' using the local API ?
When the program changed to Comfort at 17:00 it has resolved the problem :-)
