IKEA Tradfri bulbs - RGB does not work
Dear everyone,
I purchased two different IKEA TRADFRI bulbs to use them with my Zipato Zipabox (Firmware up to date, 1.3.13).
After a factory reset of the the bulbs, both of them were detected and correctly added by my Zipabox - so far, so good. One of the bulbs (980 lm, LED1545G12) works perfectly fine, including dimming and change of color temperature.
However, the other one is a RGB bulb (600 lm, LED1624G9), and for this one, only the dimmer works. I cannot change the color temperature, and although the apps show RGB mode, changing color shows no effect.
I've already removed the device, did another reset and re-added it - no effect. Could anyone help me to include this incredibly cheap and neat bulb?
Thanks in advance!
I have the same Problem, has anybody a Solution? Bulb work and dimming also. It doesnt work the Temperature and RGB-Modes without any Effect.
Same problem here!
Same problem here!
Same for me!
Same for me!
I have the same problem, does anyone have a solution for this?
Same Problem
Same Problem
Is someone working on this Problem?
If someone is still having problems with IKEA RGB Bulbs and wishes them to work properly, I might be able to investigate it a little remotely, so you can send me your Zipato controller serial number at zcerovski@3plus.hr
Zipato/Željko
Zipato/Željko
I have the Tradfri Bulp RGB for a long time. The RGB never worked for me. Today I tried to change RBG again, and, oh wonder oh wonder, it really works.
Greetings Stefan
Greetings Stefan
@Stefan
hey, that sounds interesting. I'll gie it a try later... by now I just returned all rgb bulbs, too bad.
@Stefan
Yes, I also connected my RGB Trådfri today and it worked! No word from Zipato but something positive has happend :-) //H
