Keyfob does not work after upgrade to 0.995
Wojtek T shared this problem 12 years ago
2 of my Aeon multi button key fobs stopped working after upgrading zipabox to 0.995.
Any idea?
Rules were not getting actions.
Fixed in 0.9.996.
Replies (10)
Same for me, and other rules too.
Each upgrades, same problems.
It's not the rules the problem.
There's no events with keyfob and with the second input of module (fibaro FGS or FGD) that i use for other device command.
Yesterday. after upgrade all system work very well, but from yesterday evening after 10 pm all devices doesn't work!!!
Well after some testing at this place devices and switches are working. However rules are not fired. I have some rules in a timescheduler they simply do not work. And a rule that is fired after i press a button on a remote they does not work.
Fixed in 0.9.996.
Ok, After applying firmware update 0.9.996 everything is ok her.
Yes, better now.
Check your upgrade before publish, please.
Merry Chrismas everybody
With new firmware 0.9.996, I have the same problem ...
I have deleted all devices ... and it's impossible to install again (before I have removed them as procedure)
Could you help me, please?
Thanks Darko,
All working well now ;)
