Virtual weather station
jean martin inesta shared this problem 12 years ago
Hello, I have a problem with the virtual weather station. after several attempts I haven not yet managed to make it work, no information n is raised.
Replies (24)
I had the same problem. However support gave me a workaround:
1. Add the virtual weatherstation;
2. Re-apply the device descriptor (go to active devices; select virtual weather station, there you see a button to do this);
3. Do a refresh of your screen. If all goes well: you see 2 endpoints (weather and 1-day forecast). The other endpoints are hidden;
thank you very much, It works !!!
Still 0 Values. Maybe needs time. Talking about Strumica, Macedonia. Looks updated though with some new parameters.
If you still have 0 Values Try to do the following:
1. Go to http://www.wunderground.com. This is the service zipato is using.
2. Type in your city (in the search box). Check for the response.
3. Otherwise try another (big) city in your vincinity.
4. Btw: you can check on this website which real weatherstation is used.
Sorry i forgot this:
There is still a bug in it. You can not select any endpoints in rules. This is solved in a next release.
one question,
When does the virtual weather updated?
How can i see that.
The wunderground.com says: These are estimated conditions. There are no weather stations nearby
Thanks for the info.
charriernicolas wrote:
one question,
How can i see that.
One the website (http://www.wunderground.com) there is a ticker on the top of the page right bellow the location there is info about when the information is updated.
It's work for me !
thanks for this trick . . .
When I added the virtual weatherstation and re-apply the device descriptors the values are updated within a few minutes.
However there is a problem with the api of the service:
I am living in a small town in Holland and when i use this town the service gives me no values (even though i can select the town from a popup). However when i selected a big town close to me then there are no problems.
Nope. Skopje, Macedonia is also not updated. The site sayes, "Updated 32 sec ago"
Well
Well,
In that case contact support at support.zipato.com and create a ticket.
My last problem was today solved: Finally endpoints are accessible in rules.
Hello
Thank you I applied what you said John and now it works I can see my town in south France (I checked before on http://www.wunderground.com to find my city)
I have 9 weather informations to check (sometimes you have to refresh your screen
The support added Skopje, Macedonia. Thanks.
It worked when I waited a day.
But when I click meters on the adroid app when the virtual weather station is there the app crashes.
I do not have the same data On My dashboard the On the Weather HomePage.
Why is it not geting updated?
I can also see that the initial weather value for "I" (sunset)is initially 0.00 but if I change to "II" and then back I can see the sunset time.
But still not accurate...
Same problem and also issues with the iPad/iPhone app - no values at all...
Hello
for : Marseille / Marignane, France it's not OK
for Test : Paris, France it's OK
for Test : Skopje, Macedonia it's OK
I live near Marseille how to add the Station : Marseille / Marignane, France
Thank's
Bonjour,
pour Lille, France cela ne fonctionne pas.
Merci
Pour le Thoronet petit village ça marche ????
I'm trying to add a couple of places. The place/town shows up (after a couple of attempts) but not the other stations? Isn't stations supported?
http://www.wunderground.com/cgi-bin/findweather/hdfForecast?query=60.233%2C11.168&sp=IMOGREIN2
Airport Gardermoen
http://www.wunderground.com/weather-forecast/zmw:00000.1.01384
regards
After some time it showed up right and works. I think the first update from the server where wrong.
The virtual weather station seems not to work with the codes from Wunderground I...
You ought to enter the name of the city and hope that it is the correct one otherwise you need to search for the nearest city.
