HTTP POST and GET requests
Bogdan Znakharenko shared this question 12 years ago
Hi all,
I am going to purchase Zipabox and looking for HTTP POST and GET requests functionality.
Please clarify is it possible to include HTTP POST / GET as an action for rule?
example: some sensor is triggering and Zipabox makes HTTP request to specified URL with post/get parameters.
Thnx!
Replies (10)
Yep it is possible directly from the rule creator with http request puzzle part.
You can set get/post/put/delete
How to post? there is some examples?
3
you have an example to control an amplifier Yamaha with Zipbabox rules and HTTP Requests.
http://www.touteladomotique.com/forum/viewtopic.php?f=14&t=11438&p=129064#p129064
Regards,
William
William, you are my hero!!!
I've been searching the Internet on and off for a few days when I finally stumbled on your post...you solved my problem in 10 minutes :).
I've so far implemented the scene selection and on/off...works perfectly.
So thanks!!!!
Hi again,
@William: Sorry to bother you but maybe you have som insight in another integration issue. I have an LG TV that can be controlled over WiFi (sort of). It's an LG from 2013. You can control almost anything except for on and off. So I figured I use a Remotec IR-transmitter to do that. But there is no dedicated On-command and no dedicated OFF, it's a switch so if the TV is already on and I press on the TV switches off.
Hence I want to be able to check if the TV actually is on before i move on in the script (so I know if I should turn it on or not).
Any ideas?
Is there an API for the TV? You could try a HTTP call over WiFi. It it responds it's on. Else it's off.
Good idea, but I fear that it would take some time if the TV is off (probably have to wait for the timeout) but I'll check.
But you gave me another idea: If the TV doesn't respond when it's off then I could probably just ping it and see what kind of response I get (now all I have to do is to find out how to parse the response in Zipato).
If you have programming experience I'd just make a virtual sensor of it. Have a "TvOnOrOff" sensor that is 1 if the tv responds to ping, and 0 otherwise. You need some other computer to ping and post the status to the virtual sensor.
Thanks...that's what I was afraid of though. I'm quite familiar with programming but I still struggle to understand the Zipato interface....thought that I could do this within zipato.
Somehow it seems that whenever I want to go beyond the basics I end up in a dead end. But it is the way it is, I'll write a simple webservice that I'll run on my nas.
can we do the opposite way hhtp go in zipato and ativate my ir extender
