Send message when door is open for more than 10 minutes, but not if closed in the meantime
Olato shared this question 12 years ago
Hi!
I am wondering how I can send a message, if a door is open for more than 10 minutes. Of course I could trigger a rule when the door opens, then wait ten minutes, then check if door is still open and if so, send a message. But that could trigger false alarms in case the door is closed but AGAIN opened 10 minutes after the initial open.
If the repeat function would still be there I knew how to do it (check every 5 secs for door closed and stop the rule if door closed). But without repeat I do not get it.
Many thanks for any suggestions!
I think that JOIN should do the trick.
So the rule looks like:
-JOIN
-WAIT 10 minutes
-IF.. etc.
The join statement kills any execution of the same rule. SO no false alarm is triggered.
I am using this rule:
8OaXrM3Ck8B51nuoSXK4
Not sure about the fact that there could be false detection, I never tried this kind and situation and never got any false detection.
It works perfectly!
On the old hardware, we have two timerelay
1: off-delayed relay
2: on-delayed relay
1: the most common control outside delayed relay
Eg Light Bulb for 5 minutes, then turn off the light
2: The other less common is an on-delayed relay
Eg The relay may be a set to signal a certain time, eg 30 seconds and then closes the relay contact closes an on-state.
But if the relay loses its signal for 30 seconds nothing happens
When the relay is yet another time, remains a steady signal longer than 30 seconds, for example, 31 seconds relay to close a plug an on-state
This was often in alarm system to prevent false alarm.
På den gamla hårdvaran har vi två timerelay
1: off-fördröjd relä
2: on-fördröjd relä
1: den vanligaste kontrollen utanför fördröjd relä
T.ex. Ljuslampa 5 minuter, sedan stänga av ljuset
2: Den andra mindre vanliga är en on-fördröjd relä
T.ex. Reläet får ett set för att signalera en viss tid, t.ex. 30 sekunder och sedan stänger sluter reläkontakten en on-tillstånd.
Men om reläet förlorar sin signal i 30 sekunder ingenting händer
När reläet är ännu en tid, förblir en fast signal längre än 30 sekunder till exempel, 31 sekunder reläet stänga en plugg en on-tillstånd
Detta var ofta i larmsystem för att förhindra falsklarm.
