Nexa WST-512 or my Nexa LMDT-609 to my Zipato (with 433 module), it can not find them
Mikael Åberg shared this problem 12 years ago
I can not add my Nexa WST-512 or my Nexa LMDT-609 to my Zipato (with 433 module), it can not find them.
How can I get my PIR to be recognized and my wall switch to work?
Greetings,
To join the LMDT-609 we would advise you to:
1) Remove its backplate to gain access to the configuration switches. You will see a a button labeled DEL.SET
2) Select the LMDT-609 from the "Add new device" drop down list.
3) Once the countdown starts, toggle the DEL.SET button a few times and the Zipabox will detect the motion sensor.
The WST-512 is not currently supported but you can try to join it by selecting the "CoCo AWST-8800 wall switch" from the "Add new device" drop down list.
Hi, no go :-(
The pir will not be joined, have also changed batteries and as you said toggle when looking for it.
Also the wst-512 will not be joined as you described.
Please open a ticket at http://support.zipato.com/
