experience with xiaomi temperature sensor zigbee
Theo Koster shared this question 6 years ago
I have a zipabox with zigbee extension module.
I tried to add the zigbee xiaomi temp sensor, no succes. It can be joined, but no endpoints.
Has anyone else had similar experience, and possible solution ?
Is there a list of zigbee devices that indeed will work with the zigbee extension module ?
Kind regards Theo
Yes, that's right. Until now Zipato / Zigbee does not allow Xiaomi devices to join properly. That's because Xiaomi uses an own Zigbee protocol, not the "official" Zigbee protocol.
Until now Zipato never has given an official reaction on requests to support this "protocol". You can submit a ticket and see what happens.
There is a solution to workt with Xiaomi and that's given somewhere here on this forum. It involves a raspberry board and Openhab/etc with MQTT communication.
here is the list of all supported Zigbee devices in the Zipato platform:
Device name
Netvox Z800 Power socket
Netvox Z501B Wireless Remote
Netvox Z501C Wireless Remote
Internal Zigbee Module Device
Computime CTL2181E Thermostat
Develco ZHWR202 Smart Plug
OSRAM Classic A RGBW Lightbulb
OSRAM Classic A TW Dimmable Lightbulb
OSRAM Gardenspot W
Netvox Z711 Temperature and Humidity Meter
Netvox ZB02A
NYCE NCZ-3011 Door/Window sensor
NYCE NCZ-3043 Ceiling Motion Sensor
NYCE NCZ-3041 Motion Sensor
NYCE NCZ-3014 Garage Door Sensor
OSRAM Flex RGBW
CentraLite 3300 Door and Temperature Sensor
CentraLite 3305 Motion and Temperature Sensor
CentraLite 3315 Flood and Temperature Sensor
CentraLite 3310 Temperature Sensor
OSRAM Surface Light TW
ClimaxTechnology Key Fob
SZ-SMK01 Smoke Sensor
SZ-COD01 CO Sensor
Netvox Z311A Door/Window Sensor
Netvox ZB11A Motion Sensor
Netvox Z809AF On/Off switch with meter
Netvox Z602A Siren
NYCE NCZ-3045 Curtain Motion Sensor
Philio PAN13 On/Off plug with meter
NYCE NCZ-3010 Hinge Sensor
Visonic MCT-340 SMA Door/Window sensor
Philio PAN13-1 On/Off plug with meter
Philio PST03-1C Door/Window Sensor
Philio PSE03-1 Siren
ClimaxTechnology Key Fob ACE
Philio PST03-1B Motion Sensor
Philio PSG03-1 Smoke Sensor
OSRAM Plug - Lightify
CentraLite Pearl Thermostat
Lumi LM-SZ2 On/Off module
Lumi LM-SZ3 On/Off module
Lumi LM-SZ1 On/Off module
Lumi LM-DZ Dimmer Module
Lumi LM-SZ4 On/Off module
Belkin MRVL MZ100 Dimmer Module
OSRAM Classic B40 TW - Lightify
OSRAM Classic A60 W Clear - Lightify
OSRAM Surface Light W - Lightify
QMotion Roller Hard Wired
Netvox Z308E3ED Presence Tag
Kwikset 910 Door Lock
Zen Within Zen-01
OSRAM Switch 4x EU-LIGHTIFY
Lutron LZL4BWHL01 Remote
Centralite 3420 Night Light Repeater
Centralite 4257050-ZHAC Dimmable Light
Centralite 4257050-RZHAC On/Off
OSRAM Gardenspot RGB
OSRAM PAR 16 RGBW - Lightify
OSRAM PAR16 TW Dimmable Lightbulb
Yale YRD220 Door Lock
Centralite 3115 On/Off with Meter
Wintop zTestOnOff
Wintop zPlugEnergy On/Off Plug With Meter
CentraLite 3130 Smart Switch
Everspring EVSP-SM602 Door/Window Sensor
Everspring EVSP-SM601 Motion Sensor
Everspring EVSP-SR601 Keyfob
Everspring EVSP-SR611 Panic Button
Wintop Door/Window Sensor
3460-G Smart Button
CentraLite 3328-D Micro Motion Sensor
3323-G Micro Door and Temperature Sensor
Centralite 3200-G On/Off
3315-G Water and Temperature Sensor
CentraLite 3310-G Temperature Sensor
CentraLite 3325-S Motion and Temperature Sensor
CentraLite 3326-L Motion and Temperature Sensor
eCozy Thermostat
OSRAM Surface Light W C LIGHTIFY
Ubisys Dimmer D1
OSRAM Lightify A19 RGBW
Centralite 3200-sgb On/Off
OSRAM LIGHTIFY RT Tunable White
OSRAM LIGHTIFY Dimming Switch
Centralite 3400-G Security Keypad
OSRAM LIGHTIFY A19 Tunable White
Leedarson ZHA Clear White
Heiman RGBW
OSRAM LIGHTIFY BR RGBW
OSRAM LIGHTIFY BR Tunable White
OSRAM LIGHTIFY Flex RGBW
OSRAM LIGHTIFY Gardenspot RGB
Heiman HS2SK-E On/Off Plug With Meter
Heiman HS1DS-M Door Sensor
Heiman HS1MS-M Motion Sensor
Heiman HS1CA-M CO Sensor
Heiman HS1SA-M Smoke Sensor
Heiman HS1WL-M Water Leak Sensor
Heiman HS1CG-M Gas Sensor
Heiman HS1HT-M Temperature and Humidity Sensor
Heiman HS1RC-M Remote Controller
Heiman HS1EB-M Panic Button
OSRAM LIGHTIFY Outdoor Flex RGBW
OSRAM LIGHTIFY Indoor Flex RGBW
OSRAM Gardenspot RGBW-Lightify
Innr RS 122 Bulb
Zipato Bulb 2
Enerlites ZB500D On/Off Module
Enerlites ZB15R On/Off Module
Enerlites ZB-333 On/Off Plug
TRADFRI Remote Control
Leedarson ZHA Tunable White
Leedarson ZLL Tunable White
Leedarson ZLL Clear White
Zipato Smart Smoke Sensor
CO Sensor
Zipato Smart Gas Sensor
Leedarson ZLL CCT Controller
HS1WL-M Flood Sensor
IKEA TRADFRI Bulb E27 WS Clear 950lm
IKEA TRADFRI Bulb E27 WS opal 980lm
IKEA TRADFRI Bulb E14 WS Opal 400lm
Lumi LM-DOOR Multi Sensor
Lumi LM-PIR Multi Sensor
Leedarson On/Off Plug & Meters
IKEA FLOALT panel WS 30x30
IKEA TRADFRI bulb GU10 WS 400lm
IKEA TRADFRI bulb E14 W op/ch 400lm
IKEA TRADFRI bulb E27 opal 1000lm
IKEA of Sweden TRADFRI bulb GU10 W 400lm
IKEA FLOALT panel WS 60x60
OSRAM Smart+ RGBW Lightbulb
OSRAM Switch-LIGHTIFY
Oblo Living SPW35Z Smart Plug
Oblo Living DWS Door/Window Sensor
Oblo Living SO10M1 OnOff Module
Oblo Living D3W30 Dimmer Module
Oblo Living BSC On/Off Switch module
Stelpro Thermostat STZB402
Heiman WD V11 Siren
LUMI Weather
LDS ZHA Door/Window Sensor
6AA-SS-ZF-H0 Water Leak Sensor
LDS Smart Connector Micro
IKEA TRADFRI bulb E27 W opal 1000lm
Yale YRD210 PB DB
Danalock V3-BTZB
Philips Hue RWL021 Dimmer Switch
XingHuoYuan Triple Relay Module
XingHuoYuan Dual Relay Module
Sinope Technologies RM3250ZB Load Controller
Sinope Technologies TH1124ZB Thermostat
ZigBee Dimmer
ZigBee Dimmer 1
ZigBee Dimmer 2
ZigBee OnOff
Heiman HS1HT Temperature and Humidity Sensor
Sinope Technologies SW2500ZB OnOff
Sinope Technologies DM2500ZB Dimmer
Eurotronic SPZB0001 Valve
OSRAM Ceiling TW OSRAM
OSRAM Ceiling TW
Gardenpole Mini RGBW
Outdoor Lantern W RGBW
OSRAM Lightify Switch Mini
OSRAM MR16 TW
OSRAM Outdoor Lantern B50 RGBW
Sinope Technologies TH1300ZB Thermostat
CentraLite 3328-G Micro Motion Sensor
IKEA TRADFRI bulb E27 CWS opal 600lm
IKEA TRADFRI Control Outlet
CentraLite 3320-L Contact and Temperature Sensor
Visonic MCT-340 E Door/Window sensor
TRADFRI Transformer 30W
Heiman HS1CG-E Gas Sensor
Zigbee Temperature and Humidity Sensor
Immax IM-Z3.0-RGBW Led Bulb
ELKO ElkoDimmerZHA
Philips LTW001
IKEA TRADFRI On/Off Switch
CentraLite Pearl Glass Thermostat
3400-G 3-Series Security Keypad
IKEA TRADFRI bulb E27 WW 806lm
Profalux Tilt Blind
Profalux Rolling Shutter
Profalux Awning
Profalux Gate
Profalux Garage Door
Profalux Light
Profalux Plug
OSRAM Plug 01
Ledvance PAR16 RGBW Z3 Lightbulb
Trust International Extended Color Lightbulb
Ledvance Plug Z3
IKEA TRADFRI bulb E27 WS opal 1000lm
Thanks very much that's quite an extensive list, good to have!
