virtual switch do not work
Jose Vidal shared this problem 11 years ago
In Progress
i have made a simple rule like this
when virtual switch ON
turn ON light1
wait 5 second
turn OFF light1
and i turn on and off virtual switch manualy and nothing happens
please help
Hello Jose,
Your Rule seems OK. Have you Synchronized the Rules after you saved this Rule? Also please check if your On/Off light 1 switch is not Offline.
Regards,
Hrvoje
Hello, Hrvoje
Yes, I had tried everything, I Synchronized, rebooted, loog out, loog in, the swith works well with other rules.
I made before complicated rules and they works
This one is very simple
What i really want is to use a virtual switch to set a variable to 1 if virtual swith goes on and set it to 0 if the virtual switch goes off
and with that i will have a semaphore to do or not to do rules.
could you please try this rule
thanks
Hello Jose,
I have created the Rule you asked for and I attached it to this message.
I have also created another Rule to send me an email when I change Variable to 0 or 1, to test my first Rule.
Regards,
Hrvoje
Hello Hrvoje
All is solved, the problem was a loop in one rule
To control and avoid the loop i used a flag
thanks a lot
