Add second siren to Security Module
I have an extra 8Ohm alarm speaker that I want to connect to the security module. Can I use PGM(AUX+ configuration) for this and connect the spekaker negative pole to COM??
Martin
Hi Martin,
A speaker with only 8 Ohm resistance will exceed AUX+ power budget, please choose another siren.
Bye,
Tom
Hi Martin,
Bye,
Tom
Hi Martin,
Bye,
Tom
Hi Martin,
Bye,
Tom
You can use external power supply to power the siren and a NC contact of a 12 volt relay between bell+ and bell- that cut's off the trip line.
Or if you have battery connected you could consider following sollution:
depending on what type of siren you have.
Thanks! I did some research and suspect it is not a siren but just an extension speaker and that the old alarm could send a siren tone. The other siren I have is a Securitas SEC 01 and it use max 30mA current.
However, I have a lead battery connected and also a spare external double relay so I might use the circuit you proposed if needed to connect two sirens.
