Help whit Sen.se
Can anybody help me whit this error in the google script connector??
Annyone?
Annyone?
Did you follow these steps?
http://www.domotica-blog.nl/post/zipabox-mooie-grafieken#continue
Yes.
the grafics work in the exel part. cant export them to Sense
Yes.
cant find the Sense tipic on the forum...
Here is the link to the thread about using sen.se
You ll find some tips about how to set up the google script
https://community.zipato.com/topic/add-charts-to-meters
Hi Lars,
Don't forget to put your feed ID in the corresponding column, as you can see in my screenshot.
Please remove spaces, dot or special characters.
Hi Lars,
Hello Nicolas,
i don't really no what to do whit the feed ID, can you explain this to me.
do i have to add meter to the sen.se board and use the meter ID in the feed ID something like that?
Hello Nicolas,
Hi Lars,
You need to create a device in open.sen.se, then a feed (for example I have a feed for bedroom temperature and a feed for living room temperature). For each feed, you will have a feedID, that you will have to put in front of the device in the spreadsheet.
I don't know how to explain but I think you will have to learn how to use sen.se first.
Hi Lars,
Thanks Nicolas!
i think i have one meter working.
Thanks Nicolas!
