Can someone explain to me in very simple terms how to establish a push notification via the App and.
Mel shared this question 11 years ago
I have read several items in Community about push notifications and still confused as to how to get one up and running.
Can someone explain the easiest way to do this with examples?
Replies (7)
its as easy as sending a Email:
7b8abd17a9c857a10a1d900de87039a9
Could you please assist in showing this info in English. I am just starting to learn this stuff and it would be very helpful. Thanks.
Select message type: Push, recipient and type a message to be sent in the white box
Hi Peter,
We are glad to hear that you are exploring more complex capabilities of Zipabox.
If we understood your question correctly, following information should be helpful to you.
If you want to send data to box from any app:
- Connect to Zipabox with WEB UI, go to Device manager-> Add device -> Virtual device -> create Virtual meter
- In same Device Manager window, under Virtual network, find newly added virtual meter and click on it to expand view untill you get multiple "No name" fields.
- Press cog icon next to first "No name" field and in new "page" notice URL field. That URL field contains address that you have to enter to your application on telephone for it to send specific data to Zipabox and data will be stored in that location for you to play with it in rules.
Also please check these helpful links in our knowledge base that are related to your question:
https://community.zipato.com/knowledge-base/article/receive-push-notifications-from-zipato-controller-via-pushingbox-and-newtifry
https://community.zipato.com/knowledge-base/article/ifttt-use-if-to-control-actions-in-zipabox
https://community.zipato.com/knowledge-base/article/rule-example-ifttt-use-do-to-control-actions-in-zipabox
Zipato team
Vedran, the push message type, how does it work? I have not noticed it until now.
I am currently using Pushover (3. party) and HTTP request. Will the push message type notify my Zipato app (Android)?
Hi Marius,
Yes, push will notify your Zipato application. It even can contact Zipato applications on smartphones of other users but ONLY after you allow it on your Zipabox. For example on some specific triggers you would want PUSH to send message only to specific user and to do so you have to define that user in Users list on the left of WEB UI.
If you look at that image Lars sent, just select push in first field and in second drop down menu you will find all users that were created and select one that will recieve that push message. Other fields are subject and message body.
Try it for a while and let us know if it suits you needs or if you have suggestion how to improve it.
Zipato team
I am new to zipabox, got it a few days before christmas. I cant get The push to work with the Zipato app on iPhone. When i configure the same message to email it works fine but slow.
Mikael
