USING REMOTEC ZXT-120 with zipabox and zipamini
HI, I am new in this forum,
i have some question about the remotec zxt-120 thermostat and the zipabox
we have been using the Remotec ZXT-120, i have included in the network with no problem
however i am not able to change the thermostat setmode, i do not see the temperature bar in the web interface or the phone app.
we have a zipamini here as well and i have tryed the same, in the zipamini i am able to see the temperature bar, but still i am not able to see the way to change the temperature in the phone app
any idea on how to solve this?
Remotec FW is 1.2
and zipabox FW is 0.9.999.8a
print screen zi...
Ok. to make it work, you will need to create a Virtual termostat and use the remotec as temperature unit and also thermostat output. It should work then.
hi, thanks for your reply, is there any tutorial on how to create this virtual device with in the zipato controller?
I this this should help. https://community.zipato.com/knowledge-base/article/zipato-ir-extender-ac-configuration
it work!, good tutorial, sorry for the delay.
however the remotec device keep always the ON command to the AC it does like every 5 seconds
and i cannot turn off the ac because of this
