How can we manually change Danfoss Living Connect temperature ?
Gael Poffet shared this question 13 years ago
I just started with Zipabox and 4 Danfoss valves 014G0012.
I have all setup correctly as they are all visible on MyZipato Dashboard as Meters.
Now I would like to manually change the temparature set on the valve from the Zipato interface. How can I do that ??
I cannot used Climate option as I don't have any thermometers in the same room and thermometer in put is mandatory.
Thanks for help
Replies (7)
Then try to use a scheduler in the when as a trigger.
Have one scheduler fort the start time and an other for the stop time.
And at start set TEMP=18 and at stop set TEMP=20
One rule for start and one rule for stop.
Yes, scheduler would be an option if I want to schedule temperature changes..
But if I just want to increase by a few degrees the temprature right now I don't want to create a rules for that... I looking for a simple equivalent of the up and down button of the Danfoss valve.
A schedular rule can look like this...
if you make sure to sync the schedular-event-time with the if-time, you can have all in one rule...
ops, sorry wrong answer ;-)
don't think there is a good up/down-virtual device to use for this.
One way to do it could be to use a "virtual level control" to input the temerature (in %)
But that will just show 0% - 100% so you have to recalculate before you set the temp.
then use a virtual meter to present the calculated value, so you kan see what temp that given procent value is.
Create a Rule that triggers on the change of %level
Recalculate % to a temparature value
set METER=value
set DANFORS=value
Then you have something that you can use to change and see the set value.
But doesn't the DANFORS have that functionality????
(I don't know I don't have any thermostate)
there is no way to manually set the danfoss units... this should be implemented instead of a workaround with rules and everthing.
Your idea is nice but should not be required in my opinion... how hard could it be to make a input field at thermostats and danfoss units?
I don't think that an input field is needed. Two buttons "+/-" should be enough. Exactly as it is done on the Dafoss valve.
hi, for myself i have the same config as you, and i use the climate widget, to bypass the need of a thermostat, i create a virtual thermometer and user it in thermometerendpoint with custom as function.
I also tried that, but when I create a virtual thermometer as new device of type "Virtual meter" it never appears in thermometer endpoint in Climat config screen.
How did you do it ?
