Qubino Flush Dimmer
Jacob Wiqvist shared this question 10 years ago
http://qubino.com/products/flush-dimmer/I read on this homepage that Qubino have double tap function to go to 100% but it does not look like I have this. Is it possible to fix this in some way?
Parameter 21 or something?
If the dimmer needs a firmware update how do I fix that?
86807361ac15980efce9abd3329a1072
Best regards Jacob
You could check if that parameter is available in the manual that came with the dimmer.
I was fighting with similar problems with Qubino dimmers, and found out that my dimmers had so old firmware that all the useful features were missing. I couldn't figure out any way to update the dimmer's firmware.
Replies (9)
Dear Jacob,
as I can see from manual you can enable double click function.
Parameter no. 21 - Enable/Disable | Double click function
If Double click function is enabled, a fast double click on the
push button will set dimming power at maximum dimming value.
Available configuration parameters (data type is 1 Byte DEC):
-default value 0
-0 - double click disabled
-1 - double click enabled
Like this?
d41f205ed9cbe2f3905c6f9e74abed9c
Failed? Cant retrive from paramerter 21 size 1?
0be21e35cf716d444ecc079e424a2ede
Is there any way to update firmware?
Or if it is possible to buy a dongle that makes it possible to update any zwave device?
Try without the size (leave it empty).
No luck!
I think you have ZMNHDA2, this don't have this parameter.
On ZMNHDD1 (With Z-Wave Plus) have this parameter.
Erik
Yes I think it is ZMNHDA2. Its a shame. You can't update to get new functions!
acdc11f3ad365eada83565dbcd2eae4c
You need to send it to qubino for replacement. Get in touch with them and tell the problem. They should help.
