How to control Centralite Pearl Zigbee thermostat from zipatile?
Abdalrahman Hassanine shared this question 9 years ago
Hi everyone,
I have Centralite Pearl Zigbee thermostat and I've connected it to Zipatile
the device is included in the network without problems
it's supported by zipato controllers as I have been told from Zipato and Centralite
but till now I'm not able to control anything (can't change the mode or setpoint of the device... etc.)
I submitted a ticket but the problem wasn't solved
I've tried also to link it with a virtual thermostat, still not working
has anybody tried it before and it worked for him?
Thanks,,,
no sorry, have you tried deleting the thermostat and adding it again?
I have been able to add this same thermostat without any issue. After assigning endpoints and creating a virtual device thermostat (in my case there is only heating...not fan or AC). I can select either the Zipatile temperature sensor as the input or the Centralite HA thermostat and successfully read the temperature. I can also set the thermostat to off or on and witness the relay activating in the thermostat and the heating indicator activiate/deactivate. However...when attempting to run a program or set a temperature...it appears to be sending the value in degrees Celsius. This confuses my thermostat. I believe this to be just one more programming issue related to the F / C issue. Changing the settings to F doesn't always change all parts of the code it seems. This should be an easy thing for Zipato to validate and fix. Meanwhile...I'll have to manually adjust the thermostats....uggg
Have you raised a ticket with Zipato support?
Not yet familiar with opening tickets. I thought this was a moderated board and would result in tickets being opened if the issue is validated.
No, you will have to open ticket yourself. support.zipato.com same login as to the web UI.
