Netatmo API integration in zipato ( via domoticz)
It looks like the Netatmo's API integration in Zipato (native) is not on the roadmap in the short term ... strange because this company is fast growing with a lot of new products and partnership with legrand and velux
to solve this problem I would like to use the domoticz API running on my synology nas to integrate all my Netatmo devices in Zipato (the most important one for me is the temperature sensor in the different rooms and the thermostat to be able to manage the temperature in my houses (link the the danfoss valve)
who have this kind of experiences ? I support that I need to play with some virtual devices ?
thanks in advance and I hope that Zipato will put this integration on the dev map like to others
kind regards
chris
I hade Netamo weather station for a while (returned it due to some problems)
I did a lazy way via collecting all values in Domoticz and then just created a LUA script to push values to zipabox virtual meter. I know i hade a problem with one sort of values, i cant come to think of what one it was sadly. I removed all since i returned it.
Hi. Give a look to this post, it works well for me (weather station only, but adaptable to thermostat):
https://community.zipato.com/topic/netatmo-compatibility#comment-28571
yes I've looks to this one but it is difficult to setup due to the complexity of the differents requirements
have you looked into the IFTTT channel. I noticed there are Netamo Security, Thermostat and Weather station channels. You may be able to do it all there, and use a virtual meter in Zipato with the Maker Channel in IFTTT
IFTTT indeed has some channels for Netatmo, you guys could tie these to the maker channel and interact through virtual meters.
https://ifttt.com/netatmo_security
https://ifttt.com/netatmo_thermostat
did anyone found out how to connect correctly a Netatmo (Weather, Welcome or Presence) to Zipato via IFTTT?
