Netatmo API integration in zipato ( via domoticz)
Chris Gen shared this question 9 years ago
It looks like the Netatmo's API integration in Zipato (native) is not on the roadmap in the short term ... strange because this company is fast growing with a lot of new products and partnership with legrand and velux
to solve this problem I would like to use the domoticz API running on my synology nas to integrate all my Netatmo devices in Zipato (the most important one for me is the temperature sensor in the different rooms and the thermostat to be able to manage the temperature in my houses (link the the danfoss valve)
who have this kind of experiences ? I support that I need to play with some virtual devices ?
thanks in advance and I hope that Zipato will put this integration on the dev map like to others
kind regards
chris
Replies (7)
I hade Netamo weather station for a while (returned it due to some problems)
I did a lazy way via collecting all values in Domoticz and then just created a LUA script to push values to zipabox virtual meter. I know i hade a problem with one sort of values, i cant come to think of what one it was sadly. I removed all since i returned it.
ok thank's for your feedback and how did you push the data to the zipa via a script and a cron job ? via a nas ?
created
virutal device on zipabox and copied the URLS for it.
In domoticz i think i did trigger it when
new values arrive, divided the string values up into different variables and
did send them to the zipabox urls.
I can see if there is any disabled stuff
left when i come home and post it. I don’t use the domoticz from remote since
its only used for backend handling of 433 devices since I don’t trust the duo i
have
Hi. Give a look to this post, it works well for me (weather station only, but adaptable to thermostat):
https://community.zipato.com/topic/netatmo-compatibility#comment-28571
yes I've looks to this one but it is difficult to setup due to the complexity of the differents requirements
have you looked into the IFTTT channel. I noticed there are Netamo Security, Thermostat and Weather station channels. You may be able to do it all there, and use a virtual meter in Zipato with the Maker Channel in IFTTT
IFTTT indeed has some channels for Netatmo, you guys could tie these to the maker channel and interact through virtual meters.
https://ifttt.com/netatmo_security
https://ifttt.com/netatmo_thermostat
did anyone found out how to connect correctly a Netatmo (Weather, Welcome or Presence) to Zipato via IFTTT?
3
you need to use the maker (now webhooks) IFTTT channel to post a http request to a virtual meter in Zipato. Basically the same as using a google home or the old way of using the Amazon echo via ifttt.
it seems that the IFTTT applet works only if p.e. the temperature fall lower that an value. But I want the temperature to be send constantly the temperature value of the Netatmo to the Zipato and not only once. How can I do that?
