MQTT
Mohammed Alajam shared this question 6 years ago
i found new device to add ( MQTT.org )is there any documentation or help how can i use it ?
4915ff8e2cd72afeac7115b53d4bf753
I revive this topic remained unanswered.
Is it possible to install MQTT client server with this device ?
Thanks to share
You have to create a MQTT broker (i.e. Mosquitto on a different platform) With this you can select this broker in Zipato. Every defined device will publish to this broker
Thanks John but please what is a "defined device" ?
Ohh sorry: a device you have created in Zipato (Z-Wave, Zigbee, 433, virtual etc). Once you have made the link to the MQTT broker those devices are automatically publishing to this broker.
Ok thanks. I readed on forum that "i will receive the change of states only if I subscribe to the topic of device".
So I have to subscribe on booker server (or client ?) but do you know how write the subscription ?
There is a topic on this forum about that:
https://community.zipato.com/topic/mqtt-support
(to see the correct answer: hit show all and look for the answer from sebastian)
I was able to delete with API. But the get API did not reflect the deletion until I synced and I logged out and in again.
