Osram smart+ plug (zigbee)
Ste Ra shared this idea 7 years ago
Dear Zipato team,
I have tried Tadfri from Ikea with my Zipatile and the result was that I can pair all of them but only the bulb works. Outlets and sensors don't work.
Now I want to ask the question first before to spend "money for nothing" again :)
Is it possible to pair and use Osram smart+ plug with Zipatile?
Thanks!
Outlets from Ikea (smart plugs) should work. I have a couple of them working here.
Thanks for the hint John. You are correct and I confirm that IKEA Tradfri outlet works already.
I also checked the IKEA motion sensor (again) but it's still visible as an unknown sensor - don't work.
Good to hear that. Concerning your motion sensor: submit a ticket with the question to support this sensor. I did that with the powerplug and was lucky. However keep in mind that the most of the IKEA devices are not totally Zigbee compliant. I.e the powerplug reported itself as a dimmer, which is not the case, so Zipato made some adjustments.
Good luck with your sensor!
Hi (2),
You can try to change the type of this sensor in the device manager. I am not sure if this is possible for this type of sensor.
