Components
- Zipato Zipatile Controller
Process:
- 1. To move apps, go to app menu, and choose which app you want to move
- 2. To move an app you have to touch the app and hold it
- 3. When the app is ''in the air'' you can move it wherever you want, and to place it, simply remove your finger from the screen
- 4. If you want ot remove app from home screen, hold the app and drag it to the remove section
- 5. If you want to delete the app permanently, go to the app menu, choose the app you want to uninstall
- 6. Hold the app, and drag it to uninstall section
*NOTE: Zipatile supports 32 GB SD card, speed class from 2-10
